Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Rear Driver side Strut Mount rumbling against the body
View Single Post
Old 05-12-2009, 12:36 AM   #11 (permalink)
500KCamry
View 500KCamry's Photo Gallery
Originally Posted by ghettosled View Post
sounds like it not the connection between the car and the mount is loose, but rather the strut to the mount. this is something you can check yourself. instead of checking the torque of the three bolts connecting the mount to the car, tighten the center nut that connects to the top of the strut. that has to be very tight.
on a previous car of mine i didnt torque this nut down enough and it made a sound similar to yours. it was tight, but not tight enough.
Were the insulators, the rubber parts between the spring and the shock housing replaced, are they damaged. The upper one is called "upper seat" and the lower one is called the lower insulator. If the rubber is damaged the spring would contact the metal housing and convey road noise to the car body.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
