05-13-2009, 05:06 PM
#11 (permalink)
Ninja wrench anywhere
Originally Posted by GT4times2
I'm sorry, I failed to mention that. This car has been throwing codes for a while. I had the mechanic check it on his scanner. We got: Cylinder bank 2, (I think it was 2) running lean, for one . We put a fuel psi gauge to see if it was the fuel delivery (checked fuel pump/lines; they were ok). He checked timing, the ignition coils. Not the problems.
He changed the ECU; still same problem (he told me he thought the Ecu was a culprit/Wrong again). I bought a set of injectors on Ebay (did not replace them though). I will get them cleaned and balanced later on.
While changing the spark plugs, I noticed that the ones on the rear cylinder bank were not screwed in properly (literally loose)  . I am going at it, step by step. I am looking at the vacuum hoses as a culprit. The AFM area looks clean, I am still going to clean it before putting it all back together.
Once I am done, I am going to take it to get checked if I get a CEL, and take it from there.
Wow -- you've got quite the onion to peel there! Keep us posted, and good luck!
