Originally Posted by warlock
Well the speakers have different wattage for different packages that is why you won't find a derect answer. The high and low is if you are going to use to for subs(low) or mids and tweeters(high). And yes you can use the cig lighter for the remote. By it saying remote is only for a low curent 12 volt that only comes on when the cars ignition is on. And I found that the best place to run the wires is drill a hole in the firewall then run it under the carpet by the hump and on the pass side. Well I hope I help a little
Thanks that helps, can you be more clear about the high and low ? I'm talking about high input vs line out converter.
Originally Posted by MrSo0h0o
There is a lot of current that flows through that wire for a sound system, so tapping off anything other than the battery is just a fire hazard. This is why we use 0-4 gauge wire for power. Anything smaller and you run the risk of setting your car on fire lol
That's what my common sense told me, thanks for clarifying.
