Originally Posted by touringcamry
In the photo above, you have no 4 and 5 that says L R out. Are those attached to the back of your headunit or your do you have the harness?
Anything from 12-27 are detachtable, anything from 1-11 are not detachtable.
What does L-out and R-out stand for anyways ? Doesn't make sence ... Thanks
Originally Posted by warlock
ok back to the laptop. and from the picks you sent. yes you do have the rca cables needed to hook to the amp. 4 and 5 are the ones you need. so you dont need a inline or anything eles. just the cable. and you dont run the ground back to the battery just to a clean metal contact to the trunk or frame
Hemm I was wondering what is the RCA cable shipped with my Amp kit for lol. Neither subs nor Amp came with manual. So the set up should be like this ?
Thanks, and another question about the Amp. Here's the picture of the otherside of the Amp. On the right slot, it has "GND", "REMOTE" and "12V+". So can I hook up "REMOTE" and "GND" with "positive" and "negative" wires from ciga ?
