True Flow XDI Intake- NYC/NJ/CT $220
I am selling this USED (less than 3k) True Flow XDI Intake for FJ cruiser for $200.00 shipped.
Or come pick up in NYC/ N-NJ/CT
Should fit any 4.0 V6 truck.
Came off of Fj, replaced with stock for snorkel install.
Cost me $400 when I got it.
http://www.autoanything.com/air-inta...&from_search=1
Features
* The True Flow XDI Air Intake System is custom engineered for your specific make, model and year vehicle
* The XDI system filters from the inside out for maximum air flow and the greatest possible filtration surface
* Free-flowing design boosts horsepower, torque and MPGs
* The Xtreme Duty Intake gives your rig a wicked intake tone and killer under-the-hood looks
* True Flow's lifetime reusable foam-cell air filter lets all the air in and keeps all the crud out
* Powder-coated, mandrel-bent aluminum tubing creates a straight path to power
* Nylon reinforced silicone couplers smooth air flow and make for an easy install
* System includes foam filter, tubes, couplers, clamps and connectors
* The reusable foam air filter can go up to 50,000 miles between cleanings
* Your True Flow XDI Intake System is backed by a Lifetime Warranty
Description
True Flow first turned the industry upside-down with the foam-cell air filter—now they’ve turned it inside-out. The True Flow XDI (Xtreme Duty Intake) is the hottest intake system available, on or off the road.
True Flow’s revolutionary design filters from the inside out. Fresh air draws into the system’s hollow core and gets forced out through the filter. This creates maximum airflow, a beefy intake tone and the largest filtration surface possible.
The XDI scraps that restrictive factory air box for powder-coated aluminum tubing and nylon-reinforced silicone couplers. You get custom under-the-hood looks while your engine gets all the power-producing air it can handle. The kit also includes True Flow’s famous reusable foam-cell air filter.
The XDI not only bolsters performance by boosting horsepower and torque, it delivers all-out engine protection and increased fuel efficiency. And best of all, your True Flow XDI Air Intake is backed by a Lifetime Warranty.
Notes
* CARB approval is still pending for the True Flow XDI. Until certified, the XDI isn't cleared for street use in emissions-controlled states.
* Some kits do not contain mandrel-bent tubing. If you do not find mandrel-bent tubing in your kit, your vehicle's intake design may not require it.
Here's a vid- (NOT me or my item)
http://www.youtube.com/watch?v=7WgPOZJfFkU
ThaiLand/NYC
TLCA#18914 GCLC#2083 The Fj North Eastern Crew. Official Alcohol Percentage Inspector
Ti Fj TRD SE Spec (USDM & JDM TRD parts)
Demello,Digger,Fox,Rasta Skids,Camping Lab and
Dave Crums NEW Rear Trailing Arm MOUNT.
