Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Custom Apexi WS2 Exhaust Catback on Gen6 V6 (Picture intentsive)
View Single Post
Old 06-05-2009, 02:11 AM   #12 (permalink)
darksparkz
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Typically only shops that do turbo or header work would do mandrel bends for you, and charge much more for that as well. I knew well that they would do crush bends at this shop. I'm not running any type of forced induction nor nitrous, so as for a naturally aspirated engine, I would say that even crush bends with an aftermarket exhaust system should yield more gains then the OEM mufflers would.
The only other alternative then to having a shop do the mandrel bends, is to purchase a true catback from a branded manufacturer, ie TRD or Borla.
Costs for work like this can vary depending on location and what kinda shop you go to. I was able to obtain the two mufflers from a local performance shop at a fantastic price, while they retail for around $200 each for the Apexi WS2. The piping and labor for installation can vary, mine was around $400. If your able to obtain mandrel bent and complete stainless steel piping, AND purchase two branded mufflers, then you would have yourself a true catback system. Otherwise, manufacturers such as Tanabe or HKS charges around $600 or so for a catback system for the IS350.
I'll post a sound clip up later also, after all, this is still a Camry in the end, if it was a vehicle that has more of an aim towards pure performance, such as Lancer or Impreza, then that may be a different story. But thanks much for the pictures to point it out for further references.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
