okay..so here it is...assuming none of the plans fall through...
304 in and ex with stiffer valve springs, retainers, shims and keepers.
oversized trd valves
trd adj. cam gears
0.8mm trd metal head gasket
either 44 mikuni solex or 45 webbers ( with all the neccessary ignition and fuel hardware to get it running niceeeee)
equal length headers to a 2.25 exhaust
stock red hat internals ( i can't afford to go higher otherwise i would be putting some 11:1 wisecos in there)
port and polished and blueprinted
yup i will call you guys over when i satrt working on it...actually derek, jover and myself talked about having little mechanic/work on car ciphers....i know you'll be interested in that andrew....
and yes cyril...still streetable...
