Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - n00b here, need some help
View Single Post
Old 02-18-2004, 11:05 PM   #1 (permalink)
celica92gts
View celica92gts's Photo Gallery
Exclamation n00b here, need some help
My first post here...
I bought a 92 celica gts around a month ago and I love it so far. until 2 weeks ago, when the car started to choke after 10-15mins of running, as if its not getting gas. Also noted that when this happens, there's gas leaking from under the car (front middle area).
The local Toyota dealership suggested replacing the entire fuel tank and lines along with brake lines for a hefty $1500! Im taking it for a second opinion trrow, to a place thats gonna actually inspect it thoroughly before jumping to an estimate.
Anyone else have any similar expenses, I know i havent given enough info on this matter, and that it could be a variety of things at this point... but if anyone have had seen something similar happening prolly know what im talking about.. so please respond.
Here's my other question, which many of you may be able to answer..
the previous owner has an aftermarket radio in there that wasnt hooked up correctly (everytime i turned off the car, the clock was reset..).. he prolly put this one in right before selling it.. anyway, after opening everything up to look at the wiring, i learned that he had cut all the factory harnesses (totally butchered and taped everything)... its a total mess with some of the factory wire cut so sheepishly that there's barely half an inch of wire there for me to solder on to... anyway, i have the Haynes manual for the celica and it has helped me identify most of the wires.. here's my question:
In the diagram (see attached pic), i cant seem to identify what "B" is, and what "FL" is.. the rest Im guessing is ANTenna, ACCessory and AMPlifier. Anyone got a clue?
Well, appreciate any input anyone can provide.
celica92gts is offline   Reply With Quote
