Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - oil leak found!!!!
View Single Post
Old 06-23-2009, 12:37 AM   #3 (permalink)
1996camry
View 1996camry's Photo Gallery
I don't think your oil pan gasket is your problem. Your oil pump gasket went bad on your car. when your oil pump gasket goes bad, the oil leaks that can get around your oil pan.
when is your last time you have the oil pump gasket replace and cam. seals and crank seals?
I am 100% sure it's not your oil pan gasket... my car 96 Camry did the same way as you describe on this forum.. it turns out the oil pump gasket get hard old over times. they'll leak.
1996camry is offline   Reply With Quote
