Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Problem with Shift Solenoid E
View Single Post
Old 06-23-2009, 07:53 AM   #11 (permalink)
Camry LE 94
View Camry LE 94's Photo Gallery
3rd Generation
Originally Posted by JohnGD View Post
The lock-up clutch operates only at highway steady cruising speeds (low throttle). So you go into lock-up only when in OD and at steady cruising (even for a shorter period).
Maybe that explains your OD failure as you frequently shift in and out in local driving?
My OD failed because I kept it on while working, and the fluid finally got to its worst possible point and my transmission stopped shifting after a stop at a stop sign. Now I keep it off during city driving and i only put it on when im doing 40+ mph.
Camry LE 94 is offline   Reply With Quote
