Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Changing Oil
Thread: Changing Oil
View Single Post
Old 06-23-2009, 08:40 AM   #3 (permalink)
Restless_Surfer
View Restless_Surfer's Photo Gallery
Originally Posted by LeanBurn View Post
Usually the oil manufacturer fills the bottle to 946ml...50ml off 1L for the users in Canada. If you pretend the bottle is 1L and fill according to what the owners manual says for your model, you will get pretty much exactly on the full line.
For example, the 1.8L requires 4.2L with a new filter. I use (4) 946ml bottles and then another 200ml of a 5th bottle and it comes to about 1mm under the full line every time.
The dipstick is very susceptable to smearing after the car has just been running or after an oil change. I look at mine after it has sat all night and look at both sides of the dipstick, one side is usually more readable than the other. Unfortunately, after you look at the dipstick it tends to smear up the dipstick tube making a second reading pretty hard to do, so you have to let it sit for a while to get a more accurate reading.
THATS what I wanted to hear, thank you Sir!
Also, does that extra 200 ml make a difference?
Restless_Surfer is offline   Reply With Quote
