Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - T100 air conditioning...
View Single Post
Old 07-05-2009, 12:12 PM   #1 (permalink)
BamZipPow
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $869710
View BamZipPow's Photo Gallery
Lightbulb T100 air conditioning...
Ever since I got the extended cab...I noticed that the AC was sorta...weak. Checked the system and the sight glass was clear. I noticed the low pressure line (cold) ran by the passenger side exhaust. This heat radiation will decrease the amount of cooling power the AC system will have.
So I foam wrapped the pipe and put some zip ties to keep the foam from splitting back apart. I also put in an aluminum heat shield to reduce the amount of heat the foam and pipe will git attacked with. It's not ideal but it's the scrap parts I had on hand fer the moment. It feels like it's gitting much cooler in the cab and faster, too. Ambient temps outside are above 90°F and the starting temp of the cab is around 104°F. Yes...I keep the glove box door open all the time to git the max amount of air circulating (since I rarely have passengers in the front passenger seat).
Piccies...
BamZipPow is online now   Reply With Quote
The Following User Says Thank You to BamZipPow For This Useful Post:
AZDean (02-11-2012)
