Does anyone know how to remove the front seats of the avalon?
or at least point me in the right direction? i tried searching but couldn't find any diy's for this
There should be four bolts. One at each corner of the seat bracket. I think they're 12mm but double check. Remove all four bolts and wire harness(if you have power seats). You'll have to reach under the seat to find the harness. Move the seat all the way back to access the front bolts and all the way forward for the rear bolts.
is there a way to move the seat back manually? since mine is power
and i found a new replacement seat for mine but there isnt a battery in the wrecked car?
If you or someone you know has a booster pack, hook it up just long enough to power the seat. You could bring a good battery and hook it up. You could also take the good battery plus a set of jumper cables and power it that way.
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
588.4K members
Since 2001
