Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Limited w/ Nav : How can I adjust the clock?
View Single Post
Old 07-19-2009, 10:34 PM   #4 (permalink)
VorlonBlue
Tinkerer
VorlonBlue's Avatar
View VorlonBlue's Photo Gallery
I hear you, like the other comments above, it's a bit awkward. Most important, this only involves the small display not the main NAV screen and the DISP button on the steering wheel.
Step 1. Locate the DISP button on the steering wheel.
Step 2. (Make sure your small display is on the screen showing just the time) (To change the small display clicking the DISP button on the steering wheel with toggle the small display to different screens) Hold the DISP button in for about 4 seconds until the small display shows a new menu. The first option is for the Clock. Hold the DISP button down for another few seconds until the clock menu pops up. It will show the hour and minutes. The hours should be blinking. To change the hours (They only advance up) Tap the steering DISP button until you get the desired hour. Wait 5 seconds and it will advance to the minutes. Again tap the DISP button until you get it to the desired minutes. Once correct just leave it alone for about 5 seconds and you're all set.
2008 HL LTD (Mag. Gray w/Tow) - K&N Filter, Air Box Charcoal Filter Removed, Nav Override , Silverstar HLs and Fogs, White LED Footwell Lighting, White LED Int. Lighting, White LED Puddle Lights, AMSOIL Synthetic Oil w/TRD Oil Filter. JDM Lexus Horn, Visor Decals Removed, White LED Visor Lights
VorlonBlue is offline   Reply With Quote
