Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Transmission Fluid Check
View Single Post
Old 07-22-2009, 05:33 PM   #7 (permalink)
93T100Cook
View 93T100Cook's Photo Gallery
I found the plug and bought the wrench. The plug uses a 24MM wrench. It took four trips to the hardware store to figure that one out...
Anyway, I think the transmission was overfilled. When I loosened the fill bolt, less than a half quart of gear oil came out. I thought I unbolted the drain plug for a moment, but it slowed then stopped. Stuck my finger back in the fill hole and the fluid is level with the hole now.
Here's where I need your thoughts or opinions. Could excess gear oil cause the clutch/shifting problem I'm having? Would excess pressure from the fluid cause the clutch to be hard to depress?
I have no knowledge of transmission, except they make the car go when shifted.
Cook
93T100Cook is offline   Reply With Quote
