Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2000 Toyota Celica Engine Swap
View Single Post
Old 08-09-2009, 12:21 AM   #6 (permalink)
blacken
My celica loves twistys.
blacken's Avatar
View blacken's Photo Gallery
This Celica unles you spend asstons of money into it with another motor other than the zz family will not fit without alot of custom fabrication of mounts and other misc stuff.
its been done before with ticket prices in the 100k region
Best and sure way to go as it has been said before
Monkey Wrench Stroker Engine
This engine is a wonderfull blend of the 2zz-ge with some mod work done sharing some components from the 1zz-fe. The 2zz=ge is changed from a 1.8l displacement engine to a 2.0l displacement engine with much more available lower end torque over the normal 2zz motor several People refer to this engine as the 3zz-Ge similar to the engine from Japan Tuner Trial. Which also has a crate engine same as monkey wrench racing.
The guys at monkey wrench can take what you want to do with your car and can give you a rough estimate on what it will cost.
You can stick a supercharger in there ad keep mid range HP in the 200's
or go turbo and go higher or as deep as your wallet takes you.
but a supercharged stroker engine is pretty nice
after that some weight reduction on your car and you good to go
Will make proper siggy later.
(RIP) 1992 Black Toyota Paseo (AKA little blacky) (RIP)
2001 Silver Toyota Celica ( AKA - Lady Tiamat- ) (rip)
2009 Silver Toyota Corolla ( AKA - Nonameyet)
blacken is offline   Reply With Quote
