Thanks, I was just joking about clock, but lcd is messed up. I'll stick one over it. I have a newer gas tank and lines, and I chipped off any rust back from transfer case crossmember and, on a dry day, sprayed used oil with an artistic glaze sprayer on all exposed metal. Upon ramping up the front, I notice replaced power steering lines, but one ready to go? Probably the return line. I use brake cleaner many times and got rid of oil before I applied the epoxy. I'll do the same for the paint. I'm going to test the "weld" tomorrow, A day before I work. Thanks, Steve
