Hi to all i an new to this forum, and i an looking for help ,i need to change the water pump in a toyota paseo 1992 1.5 sohc ,and i an unbale to remove one of the bolt and i dont knoe if i have to remove the engine mount and brackets or if ther is any other way to du it
hi thanks to all for you fast replay , i will do it today and yes this one is a sohc but the water pump set up looks the same as the one in the picture
hi thanks for the replay i change yesterday the water pump ,but i have a question for you guys in the intake manifold of this engine shows 16 valve but it looks like a single cam so it will be 16 or only 8 ?
thanks
