If you had the OEM radio w/nav, the RED with BLACK TRACER wire is located on connector N2 pin 14. This is a 18 pin connector on back of radio.
If you didn’t have nav, the stock radio(s) don’t show the connections in the electrical drawings.
Electrical Wiring Diagram Manual, Page 28 connector 2k pin 3 has the RED with BLACK TRACER backup-light wire, looks like the best place to connect into. The over-all back-up wiring can be found on page 142 of the same manual. Overall Best bet.
Another connection point might be on the back of the combination meter page 267, hard to get to but a shorter run.
Good Luck.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
