Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Engine idling wierd?
View Single Post
Old 09-15-2009, 06:14 PM   #1 (permalink)
ecarnby
View ecarnby's Photo Gallery
Hi guys and gals.
So long story short, car wouldnt start this morning so I took the starter out which I had to take the valve cover on the front off to get to a bolt. Anyways, got the starter tested and it ended up being my battery. While while I was working around the cover, I bumped off a tubing that looked like it was leaking coolant. I put the starter back in, changed the oil ( I had to take the oil filter off to reach the other bolt) and put everything back on. The engine when started, vibrated alot and it sounds like its idling just weird up and down up and down slow vibrates. I wonder if I bumped the idle adjustment somehow when I moved the cover up to get the bolt out? I didnt touch anything else and put everything back in order. I even replaced mty plugs thinking it would be missing. Please help if you can.
Thank you !
ecarnby is offline   Reply With Quote
