Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1996 Camry - 1MZ-FE OBD II Code 0305
View Single Post
Old 09-18-2009, 08:17 AM   #5 (permalink)
Gibson99
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
Originally Posted by JohnGD View Post
Pull the plug. Refer to the NGK pictures and see if that plug is fouled.
http://www.ngksparkplugs.com/tech_su...d.asp?mode=nml
Check the plug gap and conditin of the electrodes.
Measure the resistance of the plug wire. Sometimes a break in the conductor will still measure good. So it's kinda iffy.
Check coil resistance. As others suggested, swap locations and see if the code moves (eg P0303 P0301)
Check distributor rotor/cap contacts and general condition.
Do an injector cleaning, include Chevron Techron, Seafoam and other products.
If this still doesn't solve the problem try a compression or leakdown test. But this prolonged problem likely will show up as abnormal spark plug condition (carbon foul, oil foul).
a 1mzfe doesn't have a distributor or rotor - it's coil on plug. and the 1996 version has 6 coil packs, so there are no wires to check (aside from the shorties on the bottom of each coil, and they almost never go bad. otherwise, your suggestions are correct for misfire trouble codes.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
