Originally posted by CodyjCA
yea the oil is on top of the spark plug, SOMETIMES when i start the car a cloud of smokes comes out, also i did a compression check and they are right on, all constant.
again.. i had the same problem.... i haven't researched what caused that... but basically either a chipped valve (or one not seating perfectly right) while the car is off or a slightly bad seal when the engine is cold allows a tiny bit of oil to get into the chamber....
