Originally Posted by mattcarr
I'm going to change my front brake pads tomorrow but have a couple of questions. Is it ok to spray all over the piston to get it clean with brake cleaner?
Agree with sarsman45
Where do you apply the copper grease to to stop everything sticking? My brakes piston or the calipers are sticking on me.
I recommend you get a grease that is designed specifically caliper slide pins and brake components (brake grease). Or else your caliper might still stick with regular grease. Quick example:
www.super-lube.com/silicone-brake-grease-ez-54.htm
I've heard you have to clamp the caliper hose when pushing the piston back or it could affect the brakes after like loss of brakes. Does anyone know about this im a bit worried.
Agree with sarsman45 and tigerclaws1318. Nothing horrible will happen if you push the piston back correctly with a C-clamp, brake fluid will just be pushed back into the reservior. Just pump the brakes before driving, for the reason stated before.
Has anyone got a picture step by step? one more thing is anyone have trouble with the search box on toyota nation mine doesn't work any more...................
Not yet. I plan to change mine soon with a DIY for this forum. Unsure on a date. Never had problem with the search box so far.
As of October 11, 2009.
