Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 96 T100 3.4L Tach problems..
View Single Post
Old 10-18-2009, 10:59 PM   #12 (permalink)
BamZipPow
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $869710
View BamZipPow's Photo Gallery
Wink
Originally Posted by 96Wolf View Post
took a look around the engine bay today, and im not 100% sure where to check for the coil grounds. is the ground where the coils sit on the valve cover?
does anybody have some pics or diagrams on exactly where to check?? it would be very very helpful.
The interior ground points should be behind the left and right kick panels.
The engine bay ground points start at the battery, driver side fender wall, the engine one looks to be near the air plenum close to the diagnosics port/throttle body.
Another thing to check is the harness on the back of the combination meter...yes...it means you have to tear things down to check it and the wires as well. It happens...
Not sure if you have any aftermarket radios/amps installed or not but the installer could've taken some shortcuts and screwed a screw into the wire harness that might make it tough to detect....but that's probably a long shot.
It would probably be a good thing to hunt down the factory wiring diagram fer yer year. It's come in pretty handy fer me...
BamZipPow is online now   Reply With Quote
