Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - official lexus lf-a photos & specs leaked!
View Single Post
Old 10-22-2009, 08:24 PM   #8 (permalink)
silver04rollas
Moderator
Gameroom cash: $571037
View silver04rollas's Photo Gallery
Good info. Thanks. Yes, the LF-A engine has direct injection, as per the Chief Engineer.
What are the racing statistics so far for the LF-A?? Did it run the fastest single lap in the Nurburgring 23 hour endurance race??
I was amazed when the Chief Engineer said that the car reaches from 1000 to 9000 rpm so fast that the no analog tachometer can keep up so they decided build a completely digital gauge cluster. That is so cool.
Ferrari engines typically do not sound nearly the best in exotics. The Ferrari F430 does not sound nearly as good as the Porsche Carrera GT. Maybe because it is a V8 vs V10. The LF-A sounds even better than the Porsche Carrera GT. Even at 9000 rpm, it will not sound nearly as good.
Pretty much, LF-A is the best sounding car I have ever heard.
Originally Posted by 91MR2quickNA View Post
Well the 458 utilizes direct injection and a flat plane crank. Toyota hasn't said if the LFA's motor uses direct injection. I'm sure it does as well. And a 4.5L V8, assuming all things equal, would mean a 5.625L V10.
But consider, the 5.7L Carrera GT V10 produces only 435lb-ft and is nearly a liter larger. I think its output is quite impressive. Liter per liter, the LFA produces 73.75 lb-ft, while the Carrera GT does 76.31 lb-ft. Overall, not bad.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
