thanks for all the suggestions i would like to stick with oem parts whats the best way to go about finding the part numbers so I can compare online to dealer prices??
96 camry 2.2l 4cyl
Want to replace
thermostat & gasket
timing belt
tensioner/idler
crankshaft seal
camshaft seal
oil pump seal
oil pump o-ring
water pump
rear main seal
valve cover gasket
front & rear motor mounts
belts
radiator hoses
anything i left out?? This camry needs a timing belt and leaks oil and has vibration so i figured i would go all out. Plus i bought it cheap
