Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - No Spark 1992 Toyota Corolla
View Single Post
Old 10-31-2009, 08:58 AM   #3 (permalink)
ae92gts_zero
View ae92gts_zero's Photo Gallery
Have you done preventive maintenance and tune-ups on the car?
I'd recommend:
- pulling the distributor cap off and making sure that the rotor is still in place and the locator tab hasn't given up and allowed the rotor to freespin on the dizzy shaft (happened to me one time!)
- swap the ignition coil
- go through all of the ignition-related connectors and make sure that they're not corroded
- check ground straps from engine to chassis
- pull all four plugs, attach em to their respective cords, then confirm none of 'em have spark. If none of em have spark, it's either the coil, igniter ($$), or the ECU ($$$)
- if it's none of those, you'll have to spend some time tracing a bunch of wires to confirm +12v
When you crank the motor, does it catch at all and seem like 1 or 2 of the cylinders are firing? Or does it just turn over and not catch at all?
-Carl
______________________________________________
www.ae92gts.com
1988 Toyota AE92 GT-S, Modded for Track Duty | 1997 BMW E36 M3, Mostly Stock Daily Driver | 2005 Ducati Monster with CF Termignoni Exhaust, Alternate Ride
ae92gts_zero is offline   Reply With Quote
