Originally Posted by txturbo
I think I hear a vacuum leak but can't seem to find it. I also need to figure out why the idle speed doesn't increase whn the a/c is turned on.
Both of the above might be related. The A/C idle-up valve vaccum line might have a leak.
Sometimes Toyota wraps vacuum lines with a plastic spyral wrap. I have had leaks hidden by this type of wrap, so you might want to remove this wrap if you have any, and check for leaks where it was.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
