Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Ok my first question...engine cranks but wont start
View Single Post
Old 11-05-2009, 04:20 PM   #8 (permalink)
Donald
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Originally Posted by acker View Post
I had a problem where the fan comes on when i switch the car on and wont go off
So i thought the tempreture sensor was faulty (the one on the termostat housing)
i replaced that ,but i think the wire that plugs into that must have toutched the enging
(my guess is the wire is + and the engine - )
The fan running whenever the ignition is on usually indicates that:
(1)the temp switch is bad, (you eliminated that one)
(2)the temp switch wire is broken
(3)the air conditioner high/low pressure switch is bad
(4)the air conditioner reridgerant pressure is so low that the system won't work
(5)the air conditioner high/low switch wire is broken
If the temp switch wire touches the engine it should not affect anything but the fan.
The temp switch grounds the wire to the engine when it is cold, and opens when it is hot. So that wire is normally grounding to keep the fan from running.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
