Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 22re timing issues and tapping noise NEED HELP
View Single Post
Old 11-09-2009, 03:26 PM   #1 (permalink)
BANKSY08
View BANKSY08's Photo Gallery
I recently got a 94' 2wd for free with a 22re that had a blown head gasket. I went ahead and got a reman head for it when i replaced the gasket. I got the truck running what i thought to be good. It ran fine but made a tapping noises so i adjusted the vales and it got worse. So i figured i would get a light and actually set the idle and timing and this is where all the problems are. Rite now the truck is running at about 18 degree. the spec is 5. The Idle is at about 1200 and is supposed to be 750. If i retard the distributor all the way it only takes it bac to about 12 degrees, and the tapping noise does soften some. but with the timing at 12 the truck will barely run below about 900rpm. with the engine running extremely slugglish and with no power at all. So i tried to get the timing bac some more by moving the distributor one tooth and it wouldn't even start. So then i moved it bac. Rite now Im left with a 22re running at about 12-15 btdc and an idle of 1200 with the distributor as retarded as it can get without moving a tooth and the idle screw turned down as far as it can go. Also the Idle is not constant it moves +or- 200rpm. I don't kno what to try next....any Ideas? or similar problems?
BANKSY08 is offline   Reply With Quote
