Originally Posted by cEtnA
mine is fuel injected since i'm getting the whole car for 500 i'll probably just use the 7afe ecu it should work right?
The 7A-FE ECU will not plug into the 4A-FE wiring. You will need to do some wiring modification, and this is a lot more than a weekend job. Plan on being without this car for a few weeks.
Two good things: Your car is already fuel injected, and you are getting the complete donor car, so you will have all the parts and pieces you need.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
