Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 4AFE Throttle Body Adjustment
View Single Post
Old 11-15-2009, 03:56 PM   #4 (permalink)
90 GP
Gameroom cash: $150700
View 90 GP's Photo Gallery
When engine is cold the idle air bleed elevates idle till warm . You can feel strong vacuum in the square port inside throttle body. When warmed up you shouldn't feel vacuum. It is common to get gunked up . Try spraying cleaner in the port. Also coolant passes thru it so if thermostat isn't opening that could also cause the problem as well.
90 GP is offline   Reply With Quote
