Originally Posted by toyotaspeed90
you can also put it in gear and have someone step on the brakes.
Or crank your compressor up.... sometimes I need to get it up to about 130psi before it'll crack some loose.
Automatic.
My compressor will only make 125psi.
If I am pulling the oil pan, I will use a piece of 2x4 to block the crank, but this time I was just doing the timing belt.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
