Originally Posted by toyotaspeed90
no... there's a different casting in the blocks.... the 4age block won't bolt to the trans because the diff gets in the way.... we had to even modify a 94 4afe to get it to fit on the AWD setup....
you can use the FE block itself or modify (will have to grind about 1/2" by 3" or so... don't know for sure as I wasn't there when he ground the block down) to be able to squeek the trans by the block.....
you'll need to do some custom wiring.... or find out how to mod the FE ecu.... but very few have gotten a 4age running right on a 4afe ecu....
Ive decided against the 4age swap and was wondering,
Would a 1.3l turbo from a starlet fit in fine into this car without having to modify much?
can get one of these engines cheaper then a 4age.
