03-18-2004, 06:37 PM
#3 (permalink)
N/A bites
Re: 92 Tercel Engine swap
Originally posted by Aldaman
Q1: are the transmissions compatible? i really dont want to have to replace it, as its a good transmission, and extra cost is never good.
Yes they are however the turbo tranny has a gear ratio more suited for the turbo to function. Plus it's best to buy a half cut so the tranny,suspension and wiring all come together.
Q2: There is a bit of body rust on the car, near the ground mostly, and a bit around the windshield, but the frame seems fine. A friend of mine said that if there is any rust, it means the frame is weak, and a powerful engine will tear teh car apart. Is this true?
No, it's a front wheel drive car. There is no frame between the engine and the output shafts. The body basically is there for the ride. Now the suspension and brakes need beefing, best no rust in that area.
Last question: are the ignition, water pumps, etc compatibile? if i swapped these two engines, what else would have to be changed?
There is a modification to the wiring needed and then run the turbo ecu. A few other minor mods may be needed and somebody with direct knowledge should help you once you are ready to commit.
Thanks a lot Alex
Bill
雄のハヤブサ
