Programming Instructions for Corolla, Avalon, Camry, Matrix, Echo, Highlander, others
Programming OEM Wirless Door Lock Remote Transmitters (taken from Toyota Technical Service bulletin Dated 7/19/02)-Applies to 2000-2003 Celica, 2001-2003 Echo, Highlander, Prius and RAV4, 2002-2003 Camry and Avalon, 2003 Corolla and Matrix.
1)Driver’s door open and unlocked.
2)Insert and remove (do not turn) key from ignition two times (within 5 seconds).
3)Close and open driver’s door TWICE (within 40 seconds).
4)Insert key in ignition (do not turn) and remove.
5)Close the door.
6)Turn the ignition switch from “Lock” to “ON” and back to “Lock” at about one second intervals to select the desired mode:
-1 time for ADD mode
-2 times for REWRITE mode
-3 times for CONFIRMATION mode
-5 times for PROHIBITION mode
To confirm your mode selection, the power locks will now cycle “lock” to “unlock” a number of time corresponding to your key cycles in earlier in this step.
7)For ADD or REWRITE modes, within 40 seconds of Door Lock confirmation
a)press both Lock and Unlock buttons on transmitter simultaneously for about 1.5 seconds.
b)within 3 seconds of step A, press only the Lock button for 1 second.
c)If the transmitter has been successfully programmed, the power locks will cycle “lock” to “unlock” ONCE. If there is a problem, the locks will cycle TWICE. If this occurs, verify you have the correct transmitter, and repeat the above procedure.
d)If multiple remotes are to be repropgrammed, Repeat steps A-C.
