Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Reverse Glow gauges 1999 Camry
View Single Post
Old 03-29-2004, 10:10 PM   #4 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally posted by kdrk
are you sure that will definitely solve it? because it's all the lights that the dimmer switch controls, such as the radio, temperature knobs, etc.
You have a blown fuse or a faulty dimmer switch.
By the way wrapping a wire around a fuse is a no no. The correct way to wire it up is to splice it into the parking light wire.
Use a DMM to find the correct wire.
1. Black lead from DMM to ground. Red lead from DMM to any of the wires (pick one) going into the guage cluster.
2. Turn on the parking lights and the meter should jump to +12V if you have the right wire. If you don't see +12V move onto another wire.
3. When you find the correct wire turn the parking lights on and off a few times to verify. It should jump from 0 (off) to +12V (on) everytime you turn on the parking lights.
"Skoolin' the unlearned!"
