IIM - Ksport Procomp Big Brake Kits - 8 PISTON!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Commerce > Supporting Vendor Sales
Supporting Vendor Sales Special sales, group buys and product announcements from our supporting vendors.
Closed Thread
Old 12-17-2006, 02:10 AM   #1 (permalink)
View ImageInMotion's Photo Gallery
To kick off the Kport bbk's we're having an unbeatable offer online...
check out all the toyota applications at
http://www.imageinmotion.com/ksportbigbrakekit.php
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
8-Piston Aluminum calipers
High quality brake pads
D.O.T. Compliant Stainless steel brake lines
Machined aluminum hats
Carbon steel brackets
330mm (13") large ventilated discs (17" wheels required)
Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Ksport SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194°F - 1022°F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads. The average coefficient of friction on this pad is between .46 and .53.
Ksport RC1 Race Pads:
These carbon metallic race pads are designed to give you the best stopping power possible under extreme track conditions. Optimal operation temperatures are between 480°F - 1472°F so it is not recommended for street use due to high temperature needed for optimal performance. Designed for the racer in mind to reduce brake fade under extreme conditions. The average coefficient on this pad is .5.
ImageInMotion is offline
Old 12-17-2006, 03:04 PM   #2 (permalink)
trninhds's Avatar
View trninhds's Photo Gallery
I'm very interested. Could you please send me a price for a 97 toyota camry. Also will ksport do a custom rear big brake kit??? I would definitly be interested in that too!!!
trninhds is offline
Old 12-20-2006, 01:10 AM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Damn those are some pretty good prices considering eBay is selling the same kits for $2k.
1994 Camry 2.2L LE Auto
DarkMastyr is offline
Old 12-20-2006, 01:36 PM   #4 (permalink)
damn straight......
Old 01-01-2007, 09:08 PM   #5 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
are the calipers alum? i wonder if they come in a diff color
these kits are good? anybody bought the kit yet?
abew330 is offline
Old 01-04-2007, 07:44 PM   #6 (permalink)
yes they are aluminum, they only come in the ksport orange for now... trninhds ordered a front and a rear kit just recently for his 97 camry
Old 01-05-2007, 01:32 AM   #7 (permalink)
bitch please
DarkMastyr's Avatar
Rear kits? That's certainly rare in the world of BBK's for not-so-popular cars. Did you include some sort of custom proportioning valve to ensure that a proper front/rear bias was obtained?
Old 01-08-2007, 01:15 PM   #8 (permalink)
no, unfortunately the proportioning valves aren't an option as of yet, you'll have to figure something out on that..
Old 07-08-2008, 12:21 AM   #9 (permalink)
View rx7withtimhui's Photo Gallery
so how much in USD are the 8 piston calipers? and can i fit 12 pistons on a 07' camry with 19" rims?
thank you
rx7withtimhui is offline
Closed Thread
Brake Job Totural Pimpinda93camry 3rd & 4th Generation (1992–1996 & 1997–2001) 10 10-11-2010 12:52 PM
Brake Problem Babar Introduce Yourself Here 0 10-28-2006 02:52 AM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
Big Brake Kit? TeamBigBoy Camry & Solara Lounge 3 12-21-2002 07:06 PM
