Built for the driving enthusiast, the Sustec Stabilizer emininates roll for exceptional stability and maximum tire contact patch and grip.
Unique to the Sustec Stabilizer is it's FULL CHROMEMOLY steel alloy construction. Chromemoly's strength is such that a small diameter hollow chromemoly anti-swaybar is significantly stronger than the standard solid steel anti-swaybars that are larger in diameter.
The Sustec Stabilizer has a carefully calculated OUTER and INNER diameter, for the proper amount of rigidity. The diameter and strength cannot be compared to other commonly available anti-swaybars due to the vast difference in material construction.
Chromemoly anti-swaybars have typically only been readily available to professional race users. The Sustec Stabilizer makes this lightweight, extremely functional race technology available to all motorsport enthusiasts.
MSRP: $330 cdn
TN: $300cdn (front or rear)
$580cdn if you by both
FREE DELIVERY IN THE GTA
