Maintenance on 2012 camry SE 4 Cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
7th Generation (2012-2013) Toyota Camry Discussion for years: 2012-2013
#1 Old 01-02-2012, 08:59 AM
Quoted: 0 Post(s)
(Thread Starter)
Just purchased a 2012 SE 4 cylinder. The toyota dealer says oil changes are every 10,000 miles. I think that is nuts...Anyone that has had a 2012 4 cylinder for a bit, how often and what kind of oil will you use...Thanks
MetFan53 is offline
#2 Old 01-02-2012, 09:35 AM
Quoted: 0 Post(s)
you'll get the 10K and 20k free but the ones in between are on you
me, 5k oil changes for now. not sold on the 10k thing. i am not qualified to make an expert opinion here, just simple insurance on my car. at this point I am not a believer on the 10k lof.
z27ls3 is offline
#3 Old 01-02-2012, 09:40 AM
Quoted: 0 Post(s)
10k for me and I'm hanging onto the service records. Toyota already had a major sludge problem, I don't think that they would risk another.
ewkid is offline
#4 Old 01-02-2012, 10:25 AM
Beer & steak slave
molson.david's Avatar
Quoted: 1 Post(s)
iTrader Score: 7 reviews
toyota had sludge issues on older 2.2 motors and only if owner was using cheap oil and didn't change it in time.
I had 2001 2.2 camry from 33K till 120K. 5-30 full synthetic Valvoline Synpower every 9-10K didn't have any problems.
used same oil for 2007 2.4 camry too-no issues.
toyota issued same 10K intervals on many 2010 and up models including 2.5 camry.
I see no problems with 10K intervals on 2012 camry.
any brand name synth. oil good for at least 15K and good oil will last up to 20K but I wouldn't go that long.
as soon as I'll run out of free oil changes I'm going back to Valvoline Synpower 0-20 as far as I know Synpower and Mobil 1 0-20 synth. are two best oils on the market.
2012 MGM LE
molson.david is offline
#5 Old 01-02-2012, 10:34 AM
Quoted: 0 Post(s)
last gen 4 cyl. camry has a T-SB on oil consumption. (current available t-sb)
the fix is new pistons, reengineered. 3 select fit sizes available based on cylinder wear.
take out (bad) pistons have sludge / oil residue contaminating the oil control rings. the engine then develops oil consumption issues. If i remember the updated pistons have larger oil drain holes and are designed to not accumulate oil / sludge on the piston oil rings. With dealer records the manufacturer can and is goodwilling this on cars "that are out by miles".
soooooooo. ..........we are not completely out of the sludge days, not 100%.
sorry, but for me its a 5k interval. hey its a preference right?
5 years from now there will be thousands of camry owners that did the 10k thing and others that did 5k, all probably just as happy as the other. time will tell.
for me its not the "can the oil hold" question, its all the other little details that have not yet surfaced. if a 5k interval dealer serviced 4 cyl camry comes in at 110K burning 1 qt oil every 500 miles anything is possible. the T-SB addresses the oil burners as I have witnessed firsthand.
z27ls3 is offline
#6 Old 01-02-2012, 10:44 AM
Beer & steak slave
Quoted: 1 Post(s)
^. not a toyota tech but never heard about sludge on gen.
6 oil consumption-yes. sludge-no.
and gen 6 had 5K intervals.
plus, gen 6 and gen 7 engines are different. toyota changed gen 6 2.4 to 2.5 on gen 6.5.and increased intervals to 10K -and it's a in many ways different motor. gen 7 got updated gen 6.5 motor.
2012 MGM LE
#7 Old 01-02-2012, 11:51 AM
Quoted: 0 Post(s)
Do the 5K interval on your own and 10K intervals at the dealers
like rotate between you and the dealers every 5K .... doing ever 5K is good protection for your vehicle if you're planning to keep it for a long time
c_huynh32 is offline
#8 Old 01-02-2012, 06:19 PM
Quoted: 0 Post(s)
(Thread Starter)
Thanks all for the good information!!
MetFan53 is offline
#9 Old 01-02-2012, 06:47 PM
AML
Quoted: 0 Post(s)
10k intervals have been used for decades now with synthetic oil. It's nothing new. It's been tried, done, and proven to work. There is no scientific evidence substantiating any claim that 10k intervals will result in engine problems as opposed to 5k. Just about all general tests and specific Used Oil Analyses I've read over the years have indicated that 10k intervals were just fine.
Mercedes runs 13k, BMW 15k, Porsche anywhere in between. So why can't a Toyota?
2013 Toyota Avalon Limited
2013 Toyota 4Runner Limited
2013 Toyota Camry SE V6
AML is offline
#10 Old 01-02-2012, 08:16 PM
Quoted: 0 Post(s)
why cant toyota?
when toyota can make a water pump that will make it out of warranty I'll be sold on all the rest!
z27ls3 is offline
#11 Old 01-02-2012, 08:23 PM
touringcamry's Avatar
Quoted: 0 Post(s)
If the car has a large oil sump, say 6 quarts or so and the recommended oil is synthetic, then 10000 mi really should be a non-issue because the oil works better and there is more oil to dilute the contaminants.
The Gen 6, 2.4L, has 7500mi intervals. The 5000mi interval is for severe service.
2007 Camry 2.4L 5M
touringcamry is offline
#12 Old 01-02-2012, 08:40 PM
Senior TN Member
Quoted: 0 Post(s)
Does the gen7 use synth or Dino oil from the factory?
1998 Camry 2.2L auto. 195,000 "mostly" trouble-free miles. Recently tuned up and still purrs.
1995 Geo Prizm 1.6L. 165,000 "mostly" trouble-free miles. (need to sell soon)
2011 Venza 2.7L. 9,000 miles wondering if there ever was an NVH crew assigned to Venza
redgtxdi is offline
#13 Old 01-02-2012, 09:07 PM
Quoted: 0 Post(s)
synthetic
Megayota is offline
#14 Old 01-02-2012, 09:19 PM
tpi
Quoted: 0 Post(s)
I used 10K/synthetic on my '04 once warranty expired. It had long trips, maybe I'd shorten it a little if they were short trips. The engine was spotless looking into oil fill.
On my new one I'll monitor condition of dipstick above oil level for varnish as well as what I can see in the oil fill. I drive shorter trips now. If these parts are not staying spotless I'll increase the frequency a bit. Even though a little varnish in an engine tends to be harmless.
Water pump original when sold at 135K.
tpi is offline
#15 Old 01-03-2012, 07:08 PM
Need For Speed
arabianobsession's Avatar
Quoted: 0 Post(s)
Big water pump problems have been on the 1.8 from the Corolla and the 2.4 from the Camry and Rav4. The Camry has had the 2.5 since 2010 and I haven't seen many water pumps go bad early.
I also have a 2011 Camry that requires 0w-20 and I run 10,000 mile or once a year intervals. Oil has improved, engines have improved, we aren't in every 3000 mile territory anymore
6 speed manual 2011 Camry SE
1995 Mustang-1994 Mustang GT
1985 AMC Eagle
arabianobsession is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 7th Generation (2012-2013)
User Tag List
Linear Mode Linear Mode
