Windshield distortion and defects - Toyota Nation Forum : Toyota Car and Truck Forums
7th Generation (2012-2013) Toyota Camry Discussion for years: 2012-2013
#1 Old 10-12-2012, 07:04 AM
Quoted: 0 Post(s)
(Thread Starter)
I'm wondering whether anyone else has had problems with optical distortion in the front and back windshield. When I bought my 2012 Camry LE, I quickly noticed that the rear windshield was so distorted that it was like looking though funhouse glass. The dealer saw the problem and immediately replaced the back windshield. Fixed.
Then I noticed that I had the same problem on the front windshield. If a straight object was passing by me -- something like a lamppost -- then as it went by it would look like it was wavy and distorted. The dealer could easily see the problem, so they replaced the front windshield.
The new front windshield has the same problem though. It seems to be the worst when you're looking off to the side a bit -- like peering to the right through the front windshield before you make a left-hand turn. Anyone else have these problems? I'm either the unluckiest person in the world, with three defective windshields in a row, or Toyota is manufacturing defective windshields in general.
alexr is offline
#2 Old 10-12-2012, 07:56 AM
Quoted: 2 Post(s)
take pictures please?
2012 SE I4 Loaded
5000K HID's
LED Interior Lights
LED Footwell Lighting
Plasti-Dipped Emblems
2005 SE 4 cyl. Loaded
(Wifes car, No Mods)
DANNYBOY72 is offline
#3 Old 10-12-2012, 09:24 AM
Beer & steak slave
molson.david's Avatar
Quoted: 1 Post(s)
iTrader Score: 7 reviews
sounds like aftermarket windows...
2012 MGM LE
molson.david is offline
#4 Old 10-12-2012, 12:24 PM
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the replies. The windshields are inscribed with the Toyota logo, so they seem like factory parts. Of course the original windshields were factory, and they had the problem too.
About pictures: I've tried but they don't come out. I mainly see distortion when an objection is moving across the windshield, so still photos don't work. I've tried with a home movie camera, but those shake so much that it's hard to see anything.
It's not a difficult thing to see with the naked eye, though, so if the rest of you had this problem, I think you'd notice right away.
Thanks again, everyone!
alexr is offline
#5 Old 10-12-2012, 12:43 PM
Quoted: 0 Post(s)
i havent noticed any visual distortion, BUT when i was rainx-ing the front window, i swore i could feel that it wasn't uniform...almost like there was a slight indenting dip running vertically about 1/4 of the way in from each side. i remember thinking maybe it was something to do with funneling the wind, or maybe i was just crazy and too tired. i thought i could feel it only as i was wiping across the glass quickly. no distortion though. maybe it is a defect and you just happened to be lucky enough to get 2 extreme cases!
hirsch014 is offline
#6 Old 10-12-2012, 08:42 PM
stevenredx's Avatar
Quoted: 0 Post(s)
I've had my se for about 2 weeks and I have seen this distortion in the front windshield. Very noticeable in the lower left and right bottom corners. I figure its due to the curve the windshield makes in that area.
stevenredx is offline
#7 Old 10-12-2012, 08:55 PM
Quoted: 0 Post(s)
(Thread Starter)
This doesn't seem to be because of the curve of the windshield, though I can see that too. Instead there seem to be ripples in the glass at random places across the front windshield.
Here's one way I can see it. Find an object in the distance that's straight, like a pole. Now move your head from side to side. Don't rotate your head on your neck -- that will leave you looking in another direction. Instead shift your whole body and head left and right, so that you're looking at the pole through different parts of the windshield. It ripples as it moves over certain parts of the glass.
alexr is offline
#8 Old 10-24-2012, 10:13 AM
Quoted: 0 Post(s)
I faced similar problem while taking test drive of Camry SE 2012. The symptoms were headache and slight change of vision after coming out of the car.
vicks.very.cool is offline
#9 Old 10-24-2012, 10:25 AM
Senior TN Member
Ron AKA's Avatar
Quoted: 1 Post(s)
Have not noticed any issue with any of the glass on the car. Seems perfectly normal to me.
By any chance do you wear glasses with progressive lenses? The effect you describe can be caused by progressives.
2012 Camry XLE Hybrid
Ron AKA is offline
#10 Old 10-24-2012, 12:21 PM
Beer & steak slave
Quoted: 1 Post(s)
same here.
in addition test drove couple SE's, XLE and XLE Hybrid-no issue.
2012 MGM LE
The Following User Says Thank You to molson.david For This Useful Post:
dyapanis (09-18-2013)
#11 Old 09-18-2013, 01:32 PM
Quoted: 0 Post(s)
I haven't seen this but I can't believe they won't take care of you over defective windshields! It's crazy they are letting it get to that point. Why can't they just purchase a wield shield from another glass place for you? Crazy.
GoCards81 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 7th Generation (2012-2013)
User Tag List
Linear Mode Linear Mode
