235/45/18 or 245/40/18 - Toyota Nation Forum : Toyota Car and Truck Forums
7th Generation (2012-2013) Toyota Camry Discussion for years: 2012-2013
#1 Old 03-05-2013, 07:01 AM
Quoted: 0 Post(s)
(Thread Starter)
Hi everyone,
I'm wondering if anyone can guide me in the right direction with this question. My SE V6 comes with 225/45/18 stock. I'd like to get some larger tires and have a few options in front of me. I know that 235/45/18 will make the tire a wider tire and 245/40/18 will do about the same. Will I face any issues with this? I'm going to mount them on the stock rims from Toyota.
Thanks in advance.
veenie is offline
#2 Old 03-05-2013, 07:41 AM
Quoted: 0 Post(s)
I would think going to a 245/40 would be to big. Remember that the first set of numbers is the width, with the second set (40) being the % of the width that equals the height.
Sent from AutoGuide.com App
Shiggydiggy is offline
#3 Old 03-05-2013, 08:34 AM
'13 SE
Quoted: 11 Post(s)
yeah 245 is kinda wide for a fwd family car
Camread is offline
#4 Old 03-05-2013, 10:30 AM
Moderator
Area47's Avatar
Quoted: 0 Post(s)
a 35 series would be close to the same height. the car needs a bigger foot print anyways.
12 camry se v6 256whp 231 ft lbs.
Area47 is offline
#5 Old 03-05-2013, 07:42 PM
Green Quarter?
Dammer71's Avatar
Quoted: 0 Post(s)
Originally Posted by veenie View Post
Hi everyone,
Thanks in advance.
Most tires have a recommended rim width range. The rims on the SE V6 are 7.5" wide. Realistically, the 235/45/18 is the widest tire recommended for a 7.5" rim. The minimum recommended rim width for a 245/40/18 tire is 8". You might be able to mount a 245/40/18 on a 7.5" rim, but you would be reducing the section width of the tire in doing so. So if the sectional width of that tire is 9.6" on an 8" rim, it's only going to be 9.4" on a 7.5" rim. The 235/45/18 is probably the better choice.
I doubt that there would be any real clearance issues with the 235/45/18.
2012 Camry SE V6
Dammer71 is offline
#6 Old 03-05-2013, 07:45 PM
SurajVee's Avatar
Quoted: 0 Post(s)
Re: 235/45/18 or 245/40/18
I know for a fact that highlander rims require 235 tires and those are 19x7.5 so if I were you the biggest you should run is 235/45.
Sent from AutoGuide.com Free App
SurajVee is offline
#7 Old 03-05-2013, 10:04 PM
'13 SE
Quoted: 11 Post(s)
highlanders run 245's (both 17 and 19)
Camread is offline
The Following User Says Thank You to Camread For This Useful Post:
SurajVee (03-05-2013)
#8 Old 03-05-2013, 11:28 PM
Quoted: 0 Post(s)
Hi everyone,
Thanks in advance.
It will fit. May be unnecessary, but its all your preference. I'm running my staggered wheels on my FWD car simply for appearance. And those are 255-40-18 in the rear. I'm running stock tire in front.
tpot.noc is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 7th Generation (2012-2013)
User Tag List
Linear Mode Linear Mode
