Blind Spot Monitor DIY? - Toyota Nation Forum : Toyota Car and Truck Forums
7th Generation (2012-2013) Toyota Camry Discussion for years: 2012-2013
#1 Old 02-05-2014, 09:16 PM
Initiate
Quoted: 0 Post(s)
(Thread Starter)
Perhaps the idea has been mentioned before, but has anyone tried this out?
I saw this on ebayhttp://www.ebay.com/itm/2012-CAMRY-P...08a397&vxp=mtr
Culex is offline
#2 Old 02-05-2014, 09:20 PM
It's Official
GreatAvalon's Avatar
Quoted: 11 Post(s)
^the link says its for the mirror w/o blind spot monitoring
2012 Camry SE-B/U Cam, WT liners,
full VLED Int & Ext w/ V3 Turns,
Denso D2S, Philips 4300k lows, XB LED fogs
2014 RAV4 Limited-JBL, BSM, LDA
2013 RAV4 Limited-TOTALED
GreatAvalon is offline
#3 Old 02-05-2014, 09:31 PM
Initiate
Quoted: 0 Post(s)
(Thread Starter)
i just updated it with the right link.
Culex is offline
#4 Old 02-05-2014, 09:40 PM
It's Official
Quoted: 11 Post(s)
So the part for the BSM is actually back behind the rear bumper. You would also need the radar/sonar sensors. And wire harness to if it is not pre-ran.
#5 Old 02-05-2014, 10:09 PM
Senior TN Member
laurido92's Avatar
Quoted: 4 Post(s)
I was wondering the same thing after the loaner Lexus we had had them and I thought they were pretty cool. I think our cars are pre-wired for the BSM and the touch handle (push button start). I noticed that when I was installing my turn signal mirror covers and found the below plugs which lead me to believe that it can be done. They are located in locations were lead me to believe this. I even think the turn signal wires can be connected to them and not have to be ran all the way to the fuse box as the DYI says. By the time I put two and two together I had put everything back already so I didn't mess with it. One of these days I will give it a try and see what happens. Below are the pictures that i took of the wire harness inside the doors.
'12 Camry SE I4 Limited Edition
Blizzard Pearl
laurido92 is offline
The Following User Says Thank You to laurido92 For This Useful Post:
Culex (02-06-2014)
#6 Old 02-06-2014, 06:47 AM
Initiate
Quoted: 0 Post(s)
(Thread Starter)
very nice find laurido! I think it is very awesome that many things come prewired. the convenience package at the dealer is quite expensive, to just turn around and attach these small things yourself definately saves a lot of cash. I can't wait to get my auto-dim mirror with homelink installed
Culex is offline
#7 Old 02-06-2014, 10:40 AM
Quoted: 0 Post(s)
Laurido, What wire are you pointing to there? When I get around to it Ill take a multimeter to it and see. It wouldn't surprise me if they are in there? I think getting the OEM BSM in there would be a biznatch. Maybe someone who has access to the master wiring diagrams can hook us up. I can read a wiring diagram no problem, I just need access to them.
KnightRyderx2 is offline
#8 Old 02-06-2014, 11:01 AM
Another Camry...
ben_r_'s Avatar
Quoted: 0 Post(s)
Oh yea, subscribing to this thread in case someone figures this out. I would love to have the BSM feature!
ben_r_ is offline
#9 Old 02-06-2014, 06:50 PM
Senior TN Member
laurido92's Avatar
Quoted: 4 Post(s)
Yellow wire. According to the turn signal mirror DYI, it states that yellow = left side turn signal and green= right side turn signal. I had a picture of the right side but can't find it and the wire cluster had a green wire and no yellow wire so this led me to believe that they are indeed for the turn signal mirrors. If anyone with the touch handles would take apart their door panels and see if theses plugs are connected on their set up we would know for sure. Each door has their own set of connector/cluster.
Blizzard Pearl
#10 Old 02-06-2014, 11:09 PM
Quoted: 0 Post(s)
By touch handle do you mean when you touch the handle the door unlocks the door if you have the key with you? Dont you have to have the smart key system for that?
#11 Old 02-07-2014, 03:22 PM
Senior TN Member
cipher93's Avatar
Quoted: 7 Post(s)
Count me among those who would be interested in this, though the cost could be an issue. You'll need both mirrors, sensors, and the button for inside the car. I would imagine it should all be prewired, given that is typically how cars are made now thanks to the drive to reduce variation.
cipher93 is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 7th Generation (2012-2013)
User Tag List
Linear Mode Linear Mode
