Could the atf level check be done correctly with the car on the ground? Thank you for your input.
This is how I would do it. Fusing with the hot refill method and leveling is for under the gun service techs. The only question I have is at one point I thought you could just pump it leaving the plug out but the straw in until it runs out the straw... any reason why that wouldn't work? Obviously measuring is the correct way to do it (how I would do it anyway) and the amount you lose dropping the pan shouldn't matter, but I was kind of wondering about that idea. I'm also tired and probably overlooking whatever reason would make that idea not work.Me.. I'm gonna shorten it by simply having the car up overnight in the garage at the ambient temperature of probably 60F and the new fluid out there at the same 60F , then drain and refill "blindly" without doing the jumper wires across the OBD port and the Computer software temperature reading and blah blah blah.
For what I understand is the fluid level in the pan is above the overflow tube when the car running the fluid level will be lower or almost even with the overflow (with fluid level was correctly filled before) then as the car is warming up the fluid volume increases a and it would start overflowing when fluid temp is above 113 Celsius. Maybe I'm misunderstanding.
Be careful the overflow tube lists 7 INCH POUNDS , yes inch lbs as its torque. That must be only a light finger tight , not hand tight even.I did the drain/refill. I refilled it with the same amount of fluid this time. The car drove normal so far. Next week I will do it with starting the car first then remove the drain plug to see if any fluid comes out (hope it's not). I bought 2 gallon of fluid so with only 2 quarts/drain I need to do 3 more to use up the 2 gallon of fluid. By the way I used maxlife atf just to see if it works and I think my transmission accepting it fine. Thanks in advance for your input.
See post #20 from http://www.tundratalk.net/forums/tu...t/forums/tundra-general-discussion/112638-used-transmission-fluid-analysis.htmlI called Blackstone directly. Di-rect-ly. To confirm the analysis I saw on bitog over a year ago. That combined with virgin data has led me to inderstand it is no magical potion and indeed is run of the mill in the first place.
Now as far as me changing it. I just posted that I DID change it in my Corolla just two days ago at 15k. My Camry just hit 36k and will.... When i swallow the bitter pill of the no dipstick BS... Get its several drain and fill.
So thats that.
