2012 Camry Cabin Air Filter Installation - Toyota Nation Forum : Toyota Car and Truck Forums
7th Generation (2012+) Toyota Camry Discussion for years: 2012+
post #1 of 18 Old 06-16-2012, 10:48 AM Thread Starter
Senior TN Member
Quoted: 2 Post(s)
(Thread Starter)
gen 7 2012 Camry Cabin Air Filter Installation
I bought and installed a http://www.amazon.com/CF10285-Fresh-Breeze-Cabin-Filter/dp/B001CEG90I/
Nothing wrong with the existing filter, I'm just in maintenance parts acquisition mode.
The cabin filter is a piece of cake to remove. See 2012 Toyota Camry SE: What's In There? for pictures and instructions on removing the filter.
You can vacuum, blow, and tap out the dirt from your current filter if you're not ready to replace it yet.
There's also a $3 Fram Cabin Filter Rebate ending August 31, 2012 with a limit of 2 per address.
It fits perfectly. The Fram instructions say to install it with the air flow arrow pointing down, but the 2012 Camry air flow direction is up, so I installed it with the arrow (darker, carbon treated side) facing up.
One insignificant difference I noticed is that the stock filter has 15 pleats, the Fram has 14 pleats.
The Fram filter is has a mix of active carbon and baking soda woven into the fibers of the filter. I'm not sure if the stock filter has active carbon or not.
I have not noticed any difference with this filter installed vs the stock filter, but I've only driven 20 miles or so with it and did not encounter any stinky air or vehicles in front to test it with.
When you pull out the currently installed cabin filter, look at the bottom, because that's the dirty side. I'm not sure why Toyota designed it so the dirty side is down, because this means some dirt falls down out of the filter and cannot be cleaned without disassembling the HVAC system. I wonder where the dirt that does not get blow and caught by the filter ends up and how to clean it out?
I hope this helps someone and you are .
***** 09/01/2012 CORRECTION TO DIRECTION OF AIR FLOW STATED ABOVE: *****
The air flow direction is top to bottom, as evidenced by holding a piece of paper in the air filter slot and turning the fan on. Therefore the filter should be installed with the air flow arrow pointing down, which also results in the darker charcoal covered facing down.
2012 Camry I4 SE
Toyota Owner's Manual PDFs
If my post helped you, then thank you for the thank you.
Last edited by doznI4SE; 09-01-2012 at 03:12 AM. Reason: *** CORRECTION TO DIRECTION OF AIR FLOW ***
doznI4SE is offline
The Following User Says Thank You to doznI4SE For This Useful Post:
HH2O (06-19-2012)
post #2 of 18 Old 06-16-2012, 09:22 PM
Quoted: 1 Post(s)
Originally Posted by doznI4SE View Post
I bought and installed a FRAM CF10285 Fresh Breeze Cabin Air Filter
I'll keep this in mind. How often do you expect needing to change the filter? The warranty guide states it should be cleaned at 15K or 18 months. Then replace at double that.
GCharlotte is offline
post #3 of 18 Old 06-16-2012, 10:45 PM Thread Starter
Senior TN Member
Quoted: 2 Post(s)
(Thread Starter)
I think it depends on the environment where one drives and parks their car.
I did find small pieces of grass and other in my cabin filter. I was able to tap, pick, and vacuum the filter to get the dirt out.
The filter is so easy to get out that I'd like to clean it every 6 months. I'll replace it when it starts looking grungy, even after being cleaned - and I'm not sure when that will be.
2012 Camry I4 SE
doznI4SE is offline
post #4 of 18 Old 06-17-2012, 12:18 AM
BeerSteakTxas
molson.david's Avatar
Quoted: 43 Post(s)
iTrader Score: 8 reviews
I used fram fresh breeze before on my 2007 camry -very good filters.
they keep pollen and micro dust away from passenger compartment.
you got confused by little arrow on the filter pointed UP, right?
it should be aligned with arrow on the first cover. it shows where top of the filter should be, not air flow.
if you'll remove glove box you'll see AC motor and air ducts.
it sucks air from outside, through filter and sends to evaporator.
so don't worry, all dirt will stay on the filter.
How often do you expect needing to change the filter?The warranty guide states it should be cleaned at 15K or 18 months. Then replace at double that.
here in TX I was cleaning them every couple month -just don't like to smell any dead insects and replacing filter once a year.
if you do at least 10-12K miles a year of driving and can afford extra $12-15 a year, change your filter more often than once every 36 month.
2014 XLE v6 classic silver
B-Quiet/Pioneer/Beltronics/BlackSys/25-20-5 Tint
WagnerTQ/EBCultimax
molson.david is offline
post #5 of 18 Old 06-19-2012, 08:53 PM Thread Starter
Senior TN Member
Quoted: 2 Post(s)
(Thread Starter)
What was confusing is that the edge of the Fram filter is marked "CF10285 ...... AIR FLOW v" - where v = an arrow pointing down".
The Fram instructions step 8 states:
"Install the new filter with the air flow indicator arrow printed on the side of the filter pointing down"
The OEM filter was installed with the air flow arrow pointing up - and air does flow from the bottom through the filter out the top of the filter. So I installed the Fram filter with the arrow pointing up, contrary do the Fram directions.
I'm sure this filter fits many different vehicles, and in some installations air does flow from top to bottom. In the 2012 Camry, since air is flowing from bottom through the filter out the top, if there's heavy dirt pushed into the bottom of the filter, gravity is on the side of the heavy dirt to fall down out of the bottom of the filter. I understand the light fine dirt will stick on the filter, but I'm wondering about the bigger heavier stuff .
I could see the fan through the filter hole without needing to remove the glove compartment. I also turned on the fan while the filter was removed and put my hand in the filter slot to confirm that the air flowed from bottom to top.
2012 Camry I4 SE
doznI4SE is offline
post #6 of 18 Old 06-19-2012, 11:56 PM
jcoop's Avatar
Quoted: 3 Post(s)
doznI4SE, the link to the Fram filter part says it does not fit the 2012 Camry when amazon asks the year, make, and model of your car.
"Select a Year 2012
Select a Make Toyota
Select a Model Camry
Go
This product does not fit your 2012 Toyota Camry
See similar products that fit this vehicle"
Ray
Long Island, New York
2012 Camry Hybrid XLE 1966 Shelby 427S/C Cobra1966 Ford GT40 (CAV)
2007 Nissan Murano LE
1967 Austin Mini Cooper S
jcoop is offline
post #7 of 18 Old 06-20-2012, 12:20 AM
Quoted: 1 Post(s)
I'm not sure what's going on but if you go to http://www.framcatalog.com/Application.aspx?b=F you will see the filter listed there. It takes you to:
http://www.framcatalog.com/PartDetai...b=F&pn=CF10285
Which includes:
4-2.5L F/inj. (16V) DOHC 2AR-FE [2012-2010]
and
V6-3.5L F/inj. (24V) DOHC 2GR-FE [2012-2007]
Now the weird thing is that the dedicated site for the filter also doesn't include our Camry but I'm going with the catalog lookup: http://framfreshbreeze.com/
To solve the puzzle for sure, you could call the Fram at 1.800.890.2075
post #8 of 18 Old 06-20-2012, 06:42 AM Thread Starter
Senior TN Member
Quoted: 2 Post(s)
(Thread Starter)
doznI4SE, the link to the Fram filter part says it does not fit the 2012 Camry...........
Ray,
Amazon.com's auto parts verification is often wrong as in this case.
I actually bought the filters from RockAuto.com (your neck of the woods), and these folks are professional part sellers - they list the items as fitting the 2012 Camry and as GCharlotte wrote, so does Fram.
And now for the non-disputable scientific data (+/- 1 mm ):
OEM Measured Size: 30mm x 193mm x 213mm
CF10285 Measured Size: 30mm x 194mm x 214mm
so go pull the filter, measure it, and if the dimensions match above closely, then order the CF10285 without worries .
2012 Camry I4 SE
doznI4SE is offline
post #9 of 18 Old 08-30-2012, 10:31 AM
Quoted: 0 Post(s)
FYI - I did this test on mine with my hand and couldn't necessarily tell the air flow direction. After holding a piece of paper in there, I confirmed the flow was top to bottom. I'd do the same on yours to see what results you get.
raptorhigh is offline
post #10 of 18 Old 08-30-2012, 11:38 AM
Quoted: 67 Post(s)
Shouldn't the air enter the charcoal side of the filter ?
'13 Avalon Hybrid XLE Touring, Sizzling Crimson Mica, Sandstone interior.
TAH Owner is offline
post #11 of 18 Old 08-30-2012, 06:30 PM
Quoted: 0 Post(s)
Can someone confirm to which direction airflow occurs in the 2012 model and which direction the air filter should be placed? I am confused as to which direction the black (charcoal) part should be pointed towards?
theneb is offline
post #12 of 18 Old 09-01-2012, 03:02 AM Thread Starter
Senior TN Member
Quoted: 2 Post(s)
(Thread Starter)
raptorhigh,
Thanks for the paper suggestion.
I just saw this post now and used a piece of paper as you suggested, to determine the direction of airflow.
The air does flow from the top to the bottom, as evidenced by the paper getting pulled downwards when I turned the fan on.
In that case, the air flow arrow on the Fram filter should be pointing down, which means the darker charcoal side of the filter will also be facing down.
Sorry for the confusion. Do I have this all correct now?
2012 Camry I4 SE
doznI4SE is offline
post #13 of 18 Old 12-20-2012, 04:27 PM
Quoted: 0 Post(s)
I need a quick update on this. I installed the FRAM filter too, with the arrow pointing down, i.e., the direction of airflow. Did I do it correctly? The airflow feels different from the OEM filter, wanted to make sure. Thanks. This was the easiest cabin airfilter installation EVER. Kudos to Camry design engineers on that!
theneb is offline
post #14 of 18 Old 12-20-2012, 05:30 PM
Senior TN Member
Quoted: 115 Post(s)
You did it exactly correct
I just did mine with the same Fram Fresh Breeze yesterday. It's easy to tell the air is going from top to bottom because all the debris from the outside is sitting on top.
Paul3637 is offline
post #15 of 18 Old 12-20-2012, 07:42 PM
Quoted: 2 Post(s)
Lol I remember someone here complaining on how small the glove box was. Well, this is a good reason to have it small!
Having a cabin airfilter in the Camry makes the other cars I used to own feel so dirty
2012 Camry LE Black With Ivory Interior
Mods:
-Under Dash Lighting
-Fog Light Wiring
1997 Camry Tan XLE V6
nicholas77586 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 7th Generation (2012+)
User Tag List
Linear Mode Linear Mode
Back
