I bought a used Smart Key FOB (HYQ14FBA) as well as the Techstream tool. The Techstream tool works fine, I can get into all the menus and work that magic.
However, when I try to register the extra key fob, it isn't recognized (get the message "key registration failed"). I tried erasing one of my original keys and reregistering it, that process worked fine (so I know I'm doing the registration process correctly). If I go into Door Lock diagnostics to test the extra key FOB, the car does beep (telling me the key is xmitting but the car is saying it's not registered).
After some research, it appears that you need to "reset" the ECU. In order to do that you need a TIS passcode which is made from VIN and a SEED code you get from Techstream. There is mention of some online calculators, but I couldn't find one.
Anyway, When I go into the menu to get the seed code... the box where the seed should be is blank. If I hit the copy to clipboard button and past into notepad, I get nothing.
Has anyone gone through this process on a 2012 toyota? Did you get a seed code? If so, how did you get the passcode (did you find a calculator, send to the guy in the EU, some other source?).
Any help would be greatly appreciated.
