2012 Camry SE bluetooth problem - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 7th Generation (2012-2017) Toyota Camry Discussion for years: 2012-2017
post #1 of 36 Old 02-02-2012, 05:42 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My cell phone was successfully paired with the bluetooth system in my new car and worked for about 1 month flawlessly. Then, for some unknown reason, it started failing. The phone would say it connected very briefly and then the connection (or lack thereof) would cause my phone to cycle off & back on endlessly trying to connect. I cannot make or receive a call b/c of the constant cycling and inability to connect and stay connected. I took the car to Toyota and after 4 days of research they still don't know what to do. I have tried to "re" pair it, etc but to no avail. Does anyone have ANY ideas or experience with this?? My phone is a simple Verizon Cosmos with no internet access so it can't be due to something like that. PLEASE HELP!
nortel is offline
post #2 of 36 Old 02-02-2012, 07:49 PM
jjthenovice's Avatar
Quoted: 0 Post(s)
First I would delete the device from car. Then delete all bluetooth devices from your phone. Power phone down and remove battery. After 5 secs or so put battery back in phone and power it up. If I press and hold volume knob on head unit of my car, it will reboot the system, so try that also. After you've done these steps, re-pair phone to car and see if that fixes it. If not, get another phone and see if you can pair it to the car. This way you can probably tell where the problem is. Hope this helps.
2012 XLE V6 Magnetic Grey Premium HDD Nav Smart Key
jjthenovice is offline
The Following 2 Users Say Thank You to jjthenovice For This Useful Post:
nortel (02-03-2012), rosethornil (05-13-2012)
post #3 of 36 Old 02-03-2012, 07:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just wanted to say thank you to jjthenovice for the helpful advice. Although I couldn't get the volume knob reset in the car part to work, removing all devices from each other again and resetting the cell phone battery worked. Appreciate the time you took to help! Thanks!
nortel is offline
post #4 of 36 Old 02-03-2012, 07:51 PM
Quoted: 0 Post(s)
You're welcome, glad I was useful.
post #5 of 36 Old 05-10-2012, 06:08 AM
"BlackBerry Pro"
tech-guy's Avatar
Quoted: 1 Post(s)
How to remove and pair bluetooth device
Hello,
I just bought a 2012 Camry SE and I am also having problems with my Sprint Photon Device. Just as described above sometimes my contacts options will be enabled so I can search on my contacts and sometimes they will not be available. How do I removed the registered device from the car's stereo and how do I pair it back? Also how do I delete the contacts from the stereo and how do I add them back?
Thanks
John
tech-guy is offline
post #6 of 36 Old 05-10-2012, 07:52 AM
Quoted: 2 Post(s)
Originally Posted by tech-guy View Post
Hello,
Thanks
John
First off, have you check compatibility? http://www.toyota.com/connect/ certain phones that are not compatible will intermittenly connect with the device and possibly even mirror the contacts. If completely compatible run a hard reset on the phone itself. blackberry and some older phones have issues and will even disconnect through the phone at will.
All the steps you need are in that wonderful book called the owners manual. there it will explain how to do everything you are asking *end smart ass*
Go to setup (located next to the disc insert) and under the phone you can add and delete devices. pairing will be under car multimedia when you run discovery on your phone.
2012 Chevy Cruze LT2 w/ RS package. arrives saturday 8/18/12
2012 Camry SE 2.5l - happily owned
TOYOFORMAN is offline
post #7 of 36 Old 05-10-2012, 08:43 AM
"BlackBerry Pro"
tech-guy's Avatar
Quoted: 1 Post(s)
gen 7
@ToyoForman thanks for your advice no problem with the comment.. I am cool I suffer from lazynitess and I needed a quick answer. thanks for your time and I sure will look at the website you mentioned.
tech-guy is offline
post #8 of 36 Old 05-10-2012, 08:47 AM
Quoted: 2 Post(s)
If you need anything just gimme a shout, even sometimes reading the manual people get confused.
The Following User Says Thank You to TOYOFORMAN For This Useful Post:
tech-guy (05-16-2012)
post #9 of 36 Old 05-10-2012, 09:13 AM
"BlackBerry Pro"
tech-guy's Avatar
Quoted: 1 Post(s)
gen 7
Thanks again for all of the help the website sure helped resolved my doubt. arrrgg!!! Photon seems to have many features not compatible with my phone and my car!!! Ok back to my BlackBerry.
tech-guy is offline
post #10 of 36 Old 05-13-2012, 11:05 AM
Quoted: 4 Post(s)
Well, I'm so grateful to find this. My car (2012 Camry XLE Hybrid) was also working like a champ and then two weeks later, it started exhibiting all the same problems the original poster gave above.
I'm going back to the dealer so HE can do the reset, because I have no clue.
Thanks for this post. I'm glad to know it's more likely the phone, not my $32,000 car.
Sign me,
A Rattled Rose
rosethornil is offline
post #11 of 36 Old 07-05-2012, 09:15 AM
Quoted: 0 Post(s)
Hi guys. I have problem playing music from Iphone 4s to 2012 Camry LE through Bluetooth. It was working fine for 2 weeks but now when I'm trying to play it is showing playing but no sound. It is working fine as Ipod (USB connection) but not through Bluetooth. Please help. Thanks
vinger69 is offline
post #12 of 36 Old 07-05-2012, 09:42 AM
"BlackBerry Pro"
tech-guy's Avatar
Quoted: 1 Post(s)
Hello Vinger69,
Have you tried connecting the Iphone to another Bluetooth device and do you get the same result?
Also have you tried removing the device from the register device from the Car stereo and then re register the device?
If none of the above fix the issue I suggesting taking the stereo back to the dealer and get the stereo reflashed or re programmed.
I had the same issue and dealer had to reprogram my stereo.
Hope that helps keep us posted.
tech-guy is offline
post #13 of 36 Old 07-05-2012, 09:52 AM
Quoted: 0 Post(s)
Thank you very much. Yes, I went through all those steps with no luck. I will take it to the dealer to reprogram. Thank you again.
vinger69 is offline
post #14 of 36 Old 07-05-2012, 06:00 PM
Quoted: 3 Post(s)
Check the volume on your Bluetooth on the iphone had the same thing happen to me it was off
chulo-31 is offline
post #15 of 36 Old 07-05-2012, 10:36 PM
Quoted: 0 Post(s)
Ditto x2
buddyfixit is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 7th Generation (2012-2017)
User Tag List
Linear Mode Linear Mode
« Back
