2012 Camry: Instrument Cluster Lens Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 7th Generation (2012-2017) Toyota Camry Discussion for years: 2012-2017
post #1 of 16 Old 06-13-2013, 11:46 AM Thread Starter
'94 Camry V6/'02 Sequoia
Quoted: 0 Post(s)
(Thread Starter)
Don't ask how I messed it up (long story), but I have to replace the instrument cluster lens, which is only about $30... problem is, my local dealer wants 2 hours labor @ $100per.
I'm a little clueless here, so am seeking some help from you guys who are a little more handy than I.
Much appreciated!
1994 Camry V6 XLE - Cashmere Beige (Totaled)
2002 Sequoia - White (Gone, and good riddance to the woman who drove it)
2012 Camry XLE - White
ToyotaJimD. is offline
post #2 of 16 Old 06-13-2013, 11:49 AM
BeerSteakTxas
molson.david's Avatar
Quoted: 43 Post(s)
iTrader Score: 8 reviews
can be easily done in 30 min.
hang a little, have no time to wright step by step instructions.
will do later today.
2017 Avalon XLE premium
molson.david is offline
post #3 of 16 Old 06-13-2013, 11:56 AM
It's Official
GreatAvalon's Avatar
Quoted: 884 Post(s)
Shouldn't be too hard, especially with David's write up he's going to do. I have to tell you though, I am very curious how it got messed up. But you said not to ask, so I won't
2016 Tundra - DC | Limited | TRD | 5.7 | 4x4 | Lux Pack | Ceramic Tint | Husky X-Act Contour | AMP PowerSteps | TRD Sway Bar | TRD Exhaust
GreatAvalon is online now
post #4 of 16 Old 06-13-2013, 12:37 PM
BeerSteakTxas
Quoted: 43 Post(s)
ok.
first you need to remove odometer cluster bezel.
1. lower steering column for better access.
use your fingers or wrapped into electrical tape screwdriver and pop up plastic piece on top of the steering column which is closer to the cluster bezel and hold bottom edge of the dust curtain between st. column and bezel.
2. pop out left dash cover and pull out left dash vent.
3. grab the bottom edge of the odometer cluster bezel and pull it out.
4. disconnect fog light and VSC switch harness.
5. angle bezel to yourself and slide it to the left.
6. remove 4 screws (one on each leg of the cluster), put some rag on the steering column and place cluster lens down on the rag. disconnect two connectors and slide the cluster to the left.
removing the lens.
1. use your fingers and press down lens side clips. there is 8-10 small clips on the lens, you'll need to start from one side and go around pressing them out one by one and pulling lens away from the cluster at the same time or they gonna clip back.
2. if you want no finger prints on the cluster and lens, don't touch cluster face and clean lens with LCD screen cleaner or alcohol and clean rag.
post #5 of 16 Old 06-13-2013, 07:55 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Rockin! I'll give her a try!
post #6 of 16 Old 06-14-2013, 02:04 AM
Quoted: 5 Post(s)
A plastic trim removal tool, a philip head screw drive, 10mm socket, 12mm socket, and ratchet driver, you can disassemble the car in pieces.
2012 Camry Hybrid XLE Cosmic Gray/Ivory
2011 Sienna XLE Super White
89 Supra Turbo HID Conversion
89 Supra Turbo LED Conversion
89 Supra Turbo CarPC
2004 Matrix XR CarPC A moron in a Civic Hit n Run. Total loss.
MatrixPC is offline
post #7 of 16 Old 06-13-2014, 05:44 PM
DJLEGACEE's Avatar
Quoted: 0 Post(s)
Originally Posted by molson.david View Post
ok.
removing the lens.
By any chance do you know where the flasher relay is located on the 7th Gen Camry. I read on another post that it was behind the instrument cluster. I followed these instructions and removed it but didn't see anything.
DJ LEGACEE
DJLEGACEE is offline
post #8 of 16 Old 06-13-2014, 06:43 PM
I Mod for Beer
Blochead21's Avatar
Quoted: 17 Post(s)
There is no flasher relay on the gen 7's. It's integrated into the electronics now and not replaceable.
2012 Camry SE Black
RX-350/STI-R Retro Build Thread
Blochead21 is offline
post #9 of 16 Old 06-13-2014, 06:48 PM
DJLEGACEE's Avatar
Quoted: 0 Post(s)
If that's the case then how can I install switchback LEDS for my turn signals? Or is the 14.5 compatible with the LEDs?
DJ LEGACEE
post #10 of 16 Old 06-13-2014, 06:58 PM
I Mod for Beer
Blochead21's Avatar
Quoted: 17 Post(s)
You need to search. All of these questions have been asked and answered multiple times already.
2012 Camry SE Black
post #11 of 16 Old 07-19-2014, 09:37 AM
Trd racer
tundrav8yamaha's Avatar
Quoted: 144 Post(s)
Found it thanks guys I wonder if he used armor all too laughing out loud
tundrav8yamaha is offline
The Following User Says Thank You to tundrav8yamaha For This Useful Post:
GreatAvalon (07-19-2014)
post #12 of 16 Old 07-19-2014, 11:06 AM
It's Official
Quoted: 884 Post(s)
hahahahaha that's good! Glad you found it!
Also, great job being resourceful and searching for it
post #13 of 16 Old 01-26-2016, 11:58 AM
Quoted: 12 Post(s)
ok.
removing the lens.
I having trouble removing the top of the steering column.. it separates by the cluster but by the wheel I can't seem to find the clips. I'm not interested in forcing it and breaking any clips. Got any tips? :p
DeeX is offline
post #14 of 16 Old 01-27-2016, 04:54 PM
BeerSteakTxas
Quoted: 43 Post(s)
There are 2 screws on the "steering wheel" side of the column. Turn the wheel 90 degree off center, remove one screw, then turn the wheel 180 in opposite direction and remove another screw. Then remove the screw that hold the bottom part of the cover.
post #15 of 16 Old 01-27-2016, 06:58 PM
Quoted: 12 Post(s)
I only need to remove the top portion. Where is the third screw? On the bottom?
DeeX is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 7th Generation (2012-2017)
User Tag List
Linear Mode Linear Mode
Back
