Cup Holder Lights - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 4th Generation (2013+) Specific discussion of the fourth generation Toyota Avalon
 6Likes
post #16 of 20 Old 02-17-2017, 10:54 AM
Inveterate Tinkerer
Gadgetjq's Avatar
Quoted: 29 Post(s)
Diaa,
Just read the thread. Message 4 is a series of pictures showing how to remove cup holder panels and where to connect the new wiring. Message 5 includes Toyota part numbers for the cup holders. Other posts feature pictures of the actual install. As an alternative, you could probably shop for LED cup holder lights on eBay or another retailer then follow the same instructions for access and wiring.
Cheers
CLEVERLY DISGUISED AS A RESPONSIBLE ADULT
2014 Avalon Limited w Tech Pkg + Mods
Gadgetjq is offline
post #17 of 20 Old 02-17-2017, 12:32 PM
14TAH Touring 10 TundraDC
Rebmo's Avatar
Quoted: 49 Post(s)
I ordered the parts from TRDParts, a Toyota parts dealer on the web. They first showed up as backorder since they probably are not a common stock item. But they came in about 2 weeks. I didn't make a video since a lot of my wiring assembly was done where I work (electronics assembly plant) by soldering pros. It's really pretty easy once you see the light pipes and LED housings. One tip, install the LED housings before you screw the cupholder back together because the LED housings twist to lock in and I could not twist to fit after I put the light pipes in and screwed the 2 parts of the cupholder back together. I removed the 6 screws twist installed the LED housings (2) and screwed the cupholder assy. back together for the second time.
2014 TAH Touring, Classic Silver/Black
2010 Tundra DC SR-5 Slate/Gray
Rebmo is offline
post #18 of 20 Old 02-18-2017, 02:40 AM
Quoted: 0 Post(s)
Thanks guys i'll try to do it
Diaa Ghouli is offline
post #19 of 20 Old 02-26-2017, 05:00 PM
Quoted: 3 Post(s)
Hello my friend, Where do you gets those items specially the clear rings ??? I would like to do the same. Thank You.
2013 Toyota Avalon XLE Touring V6
2005 Jeep Grand Cherokee limited 4.7L V8
Alk3r0 is offline
post #20 of 20 Old 02-26-2017, 05:35 PM
Rebmo's Avatar
Quoted: 49 Post(s)
You can get all the parts from a Toyota Dealer (See P/Ns earlier in this thread. I got my from TRDparts.com, but any OEM Toyota parts supplier can supply them. You will need to supply wire also.
Rebmo is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 4th Generation (2013+)
User Tag List
Linear Mode Linear Mode
Back
