Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - rich/lean problem with 5sfe
View Single Post
Old 04-11-2010, 12:38 PM   #3 (permalink)
Cammoe
I'll Drive Anything
View Cammoe's Photo Gallery
So what ended up being the fix for your rich lean codes, because I've got a 92 5sfe throwing them now after replacing motor. Car runs great, lots of power, but check engine light comes on and throws 25 and 26 code for to lean and to rich. Have tried lots of things all with no luck.
-Cleaned Throttle Body (replaced gasket too)
-Tested for air/vacuum leaks (none)
-Replaced fuel pressure regulator on fuel rail
-Replaced Fuel pump and fuel filter due to low fuel pressure
-Adjusted throttle position sensor
-Checked timing (at crank, cams, and distributor)
-Cleaneed spark plugs
-Replaced upstream o2
-Replaced all vacuum lines
Please help if you can
Cammoe is offline   Reply With Quote
